Two questions on Cold Booting a Flex 6400
I use my 6400 remotely, controlled by Home Assistant. I have an automation that "starts" the radio from cold:
1 Turn the PSU on
2 Wait 10s for 12V to settle down and for the Flex's internal control processor to boot.
3. Close the "remote on" relay.
I have a similar automation that reverses this, but with a 60s delay to allow the Flex's control processor to shutdown.
My questions are:
1. Are the delays long enough?
2. Is the "remote control relay" a true analogue of the from panel power switch?
I ask the latter as the SmartSDR v4.2.18 upgrade notes specify shutting the Flex down using the front panel power button.
Thanks in Advance
Gareth - M5KVK
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsHi Gareth
Those are all fine. If it was an M model, I would apply DC power and wait 2 minutes before pushing the remote on part.
Good luck, 73
- 684 The Flea Market
