Ver 4.2.20 DSP problem
K1UO Larry
Member ✭✭✭
Just loaded the new V 4.2.20 SSDR . rebooted PC and Factory reset the 8600 before using.
First thing noted that when using combinations of the DSP filters NRL, NRS,RNN or NRF would immediately stop the active DAX channel. When used individually there is no problem.
Also RNN when used by itself is introducing some sort of artifacts in the JTDX/WSJT waterfall DAX stream.
While you can use the DSP filters together, it isn't recommended to do so. I have found it to be more detrimental to the received audio quality instead of helping improve it.
YMMV
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptions@K1UO Larry please open a support ticket
- 684 The Flea Market
