Interlock is Preventing Transmission - One Band Only??
A new issue appeared for me with my 8600 on a Win 11 PC. When I attempt to Transmit in CW mode on 10M, I get a whole string of "Interlock is Preventing Transmission" box cascading on my monitor. I have restarted the radio several times- no change. Any have a cure or suggestion ??
73 Paul w2eck
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsIt helps to know what version of SmartSDR. But if the problem still persists, please open a support ticket.
sri - running 4.2.18 on Win 11 PC
73 Paul
Running an amp? Check TX Band Settings and check TX delay.
73 Dave wo2x
The problem band (s) are checked in TX Band Settings - Delay is 0.
Problem is occurring with no Amp on, and has now shifted from 10M to 20M. The issue on 10M is gone.
Will submit a ticket this morning
Tnx
Paul w2eck
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsIt needs to be set around 25ms or higher. The details are here:
Problem solved thanks to exchanging emails with Ken Wells at Flex Help Desk. Some how I had a check mark in the PTT Inhibit column for 20M. Removed that and now Transmitting fine on all bands . Now how the the check mark got there or how it possibly moved from 10M to 20M I have no idea.
73 Paul w2eck
- 684 The Flea Market
