Wi-fi Latency questions
My first attempt is going to be to try the WiFi extender recommended on the Flex web site. I could just use the extender’s single wired Ethernet port to the 8600, but I thought for 8600 to local PC comms, I could add an Gig Ethernet switch to the extender output and put the PC and 8600 on wired Ethernet to the switch, which should result in very low latency between them. I am not currently planning remote ops into the 8600, but would like the option if I can avoid re-wiring the house. Complicating matters, my friendly AI search bot says the extender adds up to 45 ms of latency. Would I be better off just adding a dongle to the 8600 and going WiFi into the main router upstairs like I did with the other rig?
Best Answers
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsExtenders are painful on a good day if you want low lantency and low jitter. If you have coax (RG6) running from one place to the other, invest in MOCA media converters. You won't be disappointed.
WiFi also has to deal with all WiFi it hears. That is your QTH and the Neighbours. :)
I would try using a WiFi gaming adapter and see how it goes first if you can't do the MOCA thing. Or, fix the cut wire if you can.
good luck
Thanks, Mike.0
RG6 coax is easy to repair unless access is an issue. The connectors are F (cable), so simple to install and a double female F connector and back in business. My previous QTH had RG6 from every room to the attic multi-coupler. I used that cable from the shack to a double female then to the fan dipole outside through the roof ridge vent. Worked well.
- 417 Community Topics
- 716 The Flea Market
- 224 SmartSDR+
- 471 SmartSDR for Mac
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 140 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 149 Contesting
