Remote Setup
I am trying to be able to run my FLEX 6500 remotely. The radio is in Knoxville, TN and I am in Huntington Beach, CA. when I am trying to run the radio remotely. I am presently in Knoxville and trying to get SmartLink to connect. When I press the TEST button the little circle next to the TEST button turns RED. I have tried AUTOMATIC and it does not work. I went to MANUAL and put in 4993 and 4994 and still not good.
My internet provider is AT&T fiber and I am using their Gateway/Router and I have gone into NAT/Forwarding and tried port forwarding 4993 and 4994 TCP and UDP and I still can't get my radio to connect to SmartLink server. What am I doing wrong here? I am used to a UPnP router and I don't have this issue.
Help, Bob W6MTM
Hi Bob
Did you run through all the steps in Chapter 9 of the manual including the PTT registration. You have to do this while you are sitting beside the radio. Without that step happening, your radio will not register.
If you are still having an issue, open a support ticket so they can help you isolate the problem.
Thanks. I have setup 3 FLEX radios for remote operation and they all worked just fine. I think I may have a problem with this AT&T Gateway/Router because it used to work. I think AT&T did some sort of update and **** things up. I might have to change ISP companies.
I just posted a similar question as I cannot get SmartLink to work with a 6600M and on the fiber gateway.
"CoPilot AI" says that it's a known issue when using the at&t supplied PACE 5268AC fiber gateway on their network (I have 1 Gbps U/D fiber). SmartLink is registered but SmartLink fails.
The "AI" says that I need to connect the 6600M to a low cost router, configure the radio and the router to port forward 4993 and 4994 (not UPnP), then tell the PACE gateway to place this router in DMZ+
I don't have a spare router and as this setup at home is to simply test the config before heading up the mountain to replace a remote 6400 being sent for repair, I will assume that I have 99% (never say "100% LOL) probabilities that it will work fine.
Any feedback will be appreciated :-)
hmmm… I would not quite trust that AI answer.
I would open a support ticket first.
A support ticket is a waste of time. AT&T has done something to their network because my Flex radios used to work. After they did some sort of update my fiber Gateway does not let the FLEX SmartLink work anymore. Like I said, it used to work just fine and now it does not. I have tried everything I know how to do and I am very familiar with the AT&T Gateway and how to configure it as far as Natting and Port forwarding goes. Also configure some of my devices to have a fixed IP address and allow by-passing.
So bottom line is that AT&T is blocking the ports that SmartLink needs or we all are just ****.
Best regards, Bob Meadows. W6MTM
T-Mobile has done something similar in different areas of their network.
73 Dave wo2x0
- 409 Community Topics
- 705 The Flea Market
- 207 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 125 Aurora
- 984 Genius Products
- 360 Tuner Genius XL
- 328 Shack Infrastructure
- 233 Networking
