Slice Master 6000
It seems that with the new DAX that Slice Master says that DAX on Slice A disabled or disabling.
Is it because the DAX does not start unless you have a program connected to DAX like WSJT-X?
Thus I'm unable to start WSJT-X from Slice Master and start it direct.
I use Slice Master for my spots
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsThe author of SliceMaster needs to update it to manage the new DAX endpoints. I did notify him a few months ago but it looks like he hasn't gotten around to it yet.
Thanks for your prompt reply.
So is there a work around or another program that we can use to unbreak this? I use this daily and had I known about this earlier, I would not have upgraded.
Any assistance is appreciated.
You can create multiple instances of WSJT pretty easily. There are both you tube videos and if you asked AI ( I run Opera) there are simple instructions. You end up with an Icon for each instance which you can label with the slice name.
Being an old guy, I did this with batch files, one for each slice.
- 688 The Flea Market
- 105 Aurora
