XVRTR as receiver port
The hardware guide says this port can be used as an auxiliary receive input. Will this only function at 28MhZ? Or is it wide banded like the standard jacks?
    KD0RC Moderator
    Hi David, they will act just like any other antenna port.
    All antenna ports can receive from 30KHz to 54Mhz (Flex-6700 is a bit different).
