SmartSDR v4.3.19 | SmartSDR v4.3.19 Release Notes
Is it worth using the built in ATU on the 6600 even if the antenna has a useable tune below 2-1?
Hi Ben, I tend to use the tuner to more closely match the antenna in those situations, but I don't think it makes much difference either way.
If you are getting full requested power out, then you are totally fine without the tuner. If you are close to the edge, a benefit of the tuner is protection against changing conditions (wind, rain, etc) that can push you over the threshold.
Useful answer thanks, I will leave it on 73 M5AFO0
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsI almost never use a Tuner if it is below 2:1. If it is above that, I go figure out whats wrong with the antenna.
The only time I do is on the bottom end of 80M when my inverted V does cut it. But, I can clearly tell that it works very poorly when out of its resonance range. Yes, the radio is happy but the antenna turns into more of a cloud warmer.
2
- 419 Community Topics
- 718 The Flea Market
- 228 SmartSDR+
- 213 SmartSDR for Maestro and M models
- 474 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 335 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
