VOX comes on by default at every disconnect on ipad 2024 17. anyone else?
Hi,
I cant seem to find a way to make smartsdr for ios leave the VOX off? I don't have any headset connected, and every time the connection drops, or I log in a new session, vox is active. I dont like that because I will be tx all sorts of garbage if I dont pull up the vox menu and turn it off each time it connect, or change profile.
I tried saving mic profile for the ipad, it works, but the vox setting is not apparently included.
I tried saving the tx profile and the global as well, while vox is off, and no help there either. each time I click use that profile, vox is back on again.
if I use a profile created by a windows laptop, ironically, that vox setting will be "off"
anyone else have this issue? latest version of ios and smart sdr best I know, it is all a new install today. thanks,
radio is flex 8400 version 4.1.5
MN
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsThe VOX setting is stored in a the MIC Profile you are using and you see how they work in Section 18 of the SmartSDR manual.
Next time it happens, make sure you new MIC profile is loaded with VOX off. These settings are stored in the actual radio and then read by SmartSDR for iOS when it connects to the radio.
- 417 Community Topics
- 716 The Flea Market
- 224 SmartSDR+
- 471 SmartSDR for Mac
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 140 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 149 Contesting
