Problem with audio after upgrade to 4.0 on 6400M
My latency screen shows an error rate of about 5.7% and the Radio RTT rate shows Error, Radio latency is about 90 to 107 ms. This is a remote connection but have tried multiple internet connections and have shut down the radio and power supply remotely several times.
Any help on what I can do to fix this would be appreciated.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsIf you are not already on 4.1.5, please do that and test. If the problem is still there, you might want to reset the radio.
Are you able to listen to the audio from the back of the radio, at least as a test?
Just saw this response. Yes the radio audio is perfect only happens when remoting into the radio. Although it seems to be a lot better after loading 4.1.5 so it may now be just the network connection itself.0
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsHave you reset the radio (not reboot).
I did from power off apply power wait 2 minutes then press and hold the power button until I got the white light then let it boot up. That did make me have to log in again and lost all my memory but didn't make any difference. It is better if I turn the frame rate to 0. Which to me sounds like network latency so maybe nothing to be done I show 18M download speed from Miami where I am removing in from. Locally I am showing 24 mps down and 21 mps up with a latency of 40 ms.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsReset the radio - the process is outlined in the release notes. If that doesn't resolve you issues, please open a support ticket and let them know you've done that.
- 419 Community Topics
- 718 The Flea Market
- 226 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 389 FLEX-8000 Signature Series
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 334 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
