operating SSB
AB7R
Hi all.
I operate mostly CW, RTTY and FT8. I tried USB to work a W1AW portable station.
Setup is an 8600, PGXL, TGXL and AG and using a blue Yeti USB mic. 20db boost is on.
NONE of the mic profiles that come in SSDR work. No audio output. If I set to Default, I get audio output but very weak. Power output is fine…just weak audio.
Any suggestions why the other mic profiles are not working? Or, How to improve my audio output?
I think Dave, WO2X, uses this setup as well. Any chance of getting your mic profile to import it?
Greg
AB7R
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsHi Greg
You need to turn on PC audio and make sure you Mic is set to the Windows Default and that TX DAX is off.
This video will actually help you out.
Thanks Mike….you da man!
- 688 The Flea Market
- 105 Aurora
