No spectrum/waterfall display on second PC
I updated to 4.1.5 on my main desktop without issues. Then I installed 4.1.5 on my laptop but after connecting the LAN connected laptop , I get no RF display on it . I hear audio coming from 8400 in the other room when I use the laptop , just no display . I have never had issues in the past when using this laptop with a 6600 . Network data shows things as "excellent".
Andy K3UK
    Each client connection is like a different user/radio connection.
    On your laptop, have you clicked PC Audio in the upper right of SmartSDR? Once you do that, it will play audio to your default sound card.
  • Andrew O'Brien
    I tried that, no luck. With PC Audio clicked on , it does mute the 8400's connected speakers but audio does not play on the laptop and there is no display of signals in SmartSDR's spectrum/waterfall.
    Andy K3UK
  • Andrew O'Brien
    I was wrong, simply turning on PC audio was not enough. After doing that I rebooted SmartSD and all is good now.
    Thanks Mike .
    You do have to make sure that your default Windows Sound device is your speakers.
    Glad you got it figured out.
  • Andrew O'Brien
    Mike (or anyone else ),
    It worked December 29 but today when booting the laptop I again get no RF signals displayed . This time PC Audio IS selected but even a reboot after selecting PC Audio does not solve the problem . DAX shows audio is present. Laptop speakers set as default sound device.
    Puzzling since I used this laptop frequently with the 6600 and Version 3.x.x SmartSDR and never had an issue .
    Andy K3UK
  • Andrew O'Brien
    Additional info . After a reboot of the 8400 and the laptop, RF display in SSDR was apparently OK . I booted WSJTX and noticed DAX was getting zero data from the radio (DAX was configured correctly) . After rebooting DAX , DAX data was flowing at 472 , however the RF display in SSDR was no longer present. It seems that I have either RF displaying in SSDR with no DAX data , or DAX data with no RF signals displayed. Network data shows an excellent connection. Laptop is within three feet of the router , 8400 is within 15 feet of router and laptop.
    Andy K3UK
  • Andrew O'Brien
    More on this … I THINK it is working reliably now . I uninstalled SSDR on the laptop and did a reinstall and everything works as expected. We will see tomorrow .
    Andy K3UK
