No Audio Running Flex SDR radio remote via Team Viewer
Ike
I've been running my Flex 6500 remote station by using Team Viewer to access the computer on the same local area network as the radio. Just recently I find the PC audio no longer flows through to my remotely connected laptop. No number of setting changes gives me any audio. Anyone else using Team Viewer in this way? If yes I'd like to compare out sound settings for both the local computer and the remote computer that is running the SDR radio.
Hi Ike, I have never been able to get audio into or out of SmartSDR using TeamViewer. I just use it to control my amp, tuner and rotator. I use SmartLink to connect SmartSDR to the radio.
OK thanks for your input. Ya, I struggled with this issue for a long time. I had it working at one point. After the latest Team Viewer and SDR updates it quite working again. I'm also having issues with something blocking both my Maestro and iPAD from connecting via Smart(not so much)link. Might be router or IP issue at my remote station. Don't know yet. So for now I'm limited to Team Viewer and FT8.0
I still have no answers. Anyone having issue with audio on remote PC when using Team Viewer to connect to the remote network computer to run Smart SDR?0
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsIke
You should use SmartSDR/SmartLink for the Radio/Audio and then just us the remote PC for all the other bits. That way, you get all the controls and audio on your local to you PC. It just works.
- 198 SmartSDR+
- 323 Shack Infrastructure
- 228 Networking
