Flex 8400M looses Network
After a few weeks my 8400M suddenly lost the Network-Connection. My Router shows that the Radio ist connected, but the Maestro not there. I can work with SmartSDR, but not with the 8400 as a standalone TRX.
After making a "cold boot" all works ok for a few hours but suddenly the same happened.
Any idea ?
    Bill posted a Chat GPT reply and I am deleting as it isn't accurate.
  • Flexed
    Flexed Member ✭✭
    What does the Network Windows tell you? Click the little bars on the button right next to the one that looks like a cellphone signal. It looks for dropped packets, which might be related to congestion or bad cable.
  • Sven O.
    Sven O. Member ✭
    Sorry but I can't touch any button on the frontpanel. At least I opened a ticket at the helpdesk an Tim tried to fix the problem. What a great service but at the end it failed.
    I have to send the radio back to get a repair. It seems that the computer of the frontpanel is broken and they will change it. Will see how long it takes.
  • Sven O.
    Sven O. Member ✭
    Now I got my 8400M back and it works again like it should. I didn't know exactly what has been repaired, but the fault happened in the frontpanel.
    Again many thanks to Tim from the Helpdesk for all he tried.
    73 Sven DL1SO
  • Sven O.
    Sven O. Member ✭
    Upgrade: After just 4 Months the same fault occurs again. Suddenly a black screen on the front panel and no function of the panel anymore. Last time the EU-Service changed the CPU of the front panel. A fault that occurs often and is well known. What a shame for such an expensive Transceiver. Now I have to talk with the Dealer here in Germany how to repair it again under the warranty and the 8400M will be offline for some weeks.
    In the moment I'm thinking if it was a good idea to buy a Flexradio and to sell it after the repair as quick as possible.
