CW settings for SO2R with N1MM
Hi everyone,
I'm trying to get things working but am still facing some issues. Does anyone have any written settings or configuration tips? I have the KE5DTO/K9CT setup documents, but the audio switching is not functioning as expected.
Thanks in advance for your help!
Ranko, 4O3A
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsHere is the public document in case others want to reference it
I found that internal switching on 6700 is not fast enough, and those short delays are simply making it useless for 2BSIQ. For standard SO2R its OK.
Thank for help0 -
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsCan you explain what you are hearing with more detail?
I am also curious if your CW Delay settings are greater than your TX Delay settings.
Hi Mike,
Thanks for the follow-up question.
What I am hearing is the following:
When the Flex 6700 switches audio using the OTRSP protocol, there is a random delay in the audio handover, and very often the first part of the caller’s first CW character is missing. Because of this, I either need the caller to repeat, or I have to ask for a repeat myself — which completely defeats the purpose of 2BSIQ operation, where timing and accuracy are critical.
In short, the speed and consistency of the audio switching is not sufficient for high-rate 2BSIQ.
I also opened another topic on the Community regarding running two Flex radios from a single PC, because in my experience that seems to be the only reliable approach for true 2BSIQ operation.
Ranko0 -
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsI created a supported ticket for this.
- 198 SmartSDR+
- 323 Shack Infrastructure
- 228 Networking
