Maestro Black square and no sound-pan adapter
I have seen several posts of this and the picture of the black square in the Pan adapter is the same as I get. So I change my MTU like all the other posts, went all the way down to 1300 and no change when I connect normal smartlink or low bandwidth option.
Test from smartlink setup on the maestro shows green.
But, when I go into Network diagnostics, it shows Excellent latency averages around 12ms. But the really strange thing is dropped packets : 0 out of 0 packets dropped.
    Please open a support ticket. But, it sounds like something is blocking the communications on your network.
  • wb0z
    Thanks Mike - problem went away after upgrading to 3.10.10 from 3.9.19. By the way love your videos, Yes no other vendor does this level of support.
