How to display spots on Maestro using SmartLink?
Fritz
Fritz Member, Unconfirmed
edited September 2025 in SmartSDR CAT
How can i send spots from N1MM (or any other spot source) on my local Windows PC to Maestro?
    Here’s how to set it up:
      • In SmartSDR CAT, make sure you have an entry called N1MMSpots. SmartSDR CAT must be running on the same computer.
      • In your case, it is already set up to listen on UDP Port 12061.
      • In N1MM+, go to Config → Broadcast Data.
      • Enable Spot Information (UDP Broadcast).
      • Set the IP Address to 127.0.0.1.
      • Set the Port to 12061 (to match the port shown in SmartSDR CAT).
      • Once configured, cluster spots in N1MM+ will be sent to SmartSDR CAT, which will inject them into your radio.
      • On your Maestro, go to Menu/Spots and make sure Spots are enabled.
      • Tune around on your Maestro’s panadapter and you should see spots appear if they are on or near any frequency in the panadapter.
  • Fritz
    Many thanks Mike.
