Two instances of JTDX/WSJTX on SmartSDR for MacOS
Hello all!. I turned my shack into a Mac shack recently (using M4 Mac Mini). I have been able to run almost everything I used to run on my Windows PC as far as the Flex is concerned (SmartSDR, JTDX, Wsjtx, Gridtracker, MacloggerDX (the best logger available) and so on.
Only drawback I've encountered so far is that if I want to use the 2 slices of my 6400 at the same time, I havent been able to do so. I´ve tried the native FT8 tool and find it useful but not as powerfull as jtdx or wsjtx and unfortunately, as far as I know, SmartSDR for Mac doesn´t allow for streaming to 2 dax channels at the same time.
I use Loopback and tools as xCAT and xDAX, to do this but to no avail. So far, xCAT does connects to SmarSDRs 2 slices and I can control them separately. BUT with xDAX it only allows me to select one Slice at a time. If I select Slice A it turns Slice B gray and viceversa. Each one of them separately does work and jtdx receives and decodes fine but no matter what I try I can´t get them both to be active at the same time.
Notes:
Radio is a Flex 6400
Mac is M4 Mac Mini
Running latest version of SmartSDR for MAC, JTDX, Loopback, xDAC, xCAT
Does anybody operates on this set up that can help me?
Thanks in advance,
73, Santiago HI8O
I’m curious as to the desire to use two copies of JTDX. Is this so you can work two different bands and/or modes simultaneously?
In my case, I use only one copy, but JTDX takes advantage of using two slices, care of the “split operation” setting - one for receive and one for transmit. I believe this method improves the transmit signal quality.
Have you tried turning JTDX Split Operation “off”?
(PS - I’m actually using “WSJT-X Improved” which I think is superior, but probably wouldn’t make a difference in your scenario.)
Thanks Bill. Yes, the idea of having 2 instances of JTDX or WSJTX at the same time is to be able to take advantage of Flex´s multiple SCU and operate 2 bands at the same time (in my case with the 6400).
I alternatively use JTDX and WSJTX Improved, but so far feels jtdx has better decoding.
73, Santiago HI8O
i am able to run macssdr and four instances of wsjtx with flex 6600m. using xdax and xcat
you can see that the four slice of macssdr are covered over by the 4 instance of wsjtx
upper right hand corner is jtbridge which consolidates all info from four wsjtx
you can see xcat in bottom center
i use a apple scrypt to start up the four instances of wsjtx which also IDs each slice A,B,C,and D
I do run multiple monitors but hti show it can be don on single monitor
although crowded and you have to choose what is important to operate
this setup keep your eyes busy and mind going around and around
as for antenna fro 20 thru 6m i have lpda at 50 ft and for 80 thru 10 have 145ft OCF at 80 ft
with 6600m i can assign best antenna per band due to two SCU of 6600m
all this run on mac mini M1 …no problem
Paul K3SF
Question…have you setup a loopback for each dax channel ( 1 thru 2)
you can see i have dax1 and dax2 builtin my loopback devices
the you can select them in xdax
Paul K3SF
Thanks Paul. That is exactly what I´m looking to do. I will follow your explanations and examples to see if I can get it working. As far as the loopback devices yes, I have 2, one for Slice A and one for Slice B.
THanks a lot for your comments and photos, I have my homework for tonite.
73, Santiago
HI8O
Hi Santiago,
Another xDAX item - if you will be transmitting from digital mode app (JTDX, WSJT-X, FLDIGI, etc.), you may find that xDAX TX does not work.
Symptom: no horizontal audio bar activity is seen in xDAX TX Stream section, while transmitting.
xDAX was last updated some years ago, and isn’t doing something the newer Sequoia needs. Prevents MacOS Sequoia from knowing xDAX needs microphone access.
MacOS doesn’t ask if xDAX should be granted access to the mic. So, xDAX TX won’t work.
There’s a manual workaround, if you are comfortable working with Terminal and sqlite3 SQL commands.
Search Flex Forum for discussion titled “Loopback and xdax on a Mac”. Starts September 2024, ends January 30, 2025.
Long thread - but, the basic solution is found in two postings by ChrisAC9KH:
- January 26. Is about inserting xDAX into the mic list using SQL.
- Third-to-last posting, Jan 30. Need to grant Full Disk Access to Terminal, before doing above step 1).
It’s been long enough that I might have forgotten something - hope not…
Mike WA7IJV
Thanks Mike. Will look into it. As matter of fact, I´ve been working fine on jtdx and wsjtx using xDax Tx.
Paul @K3SF I got everything working following your guidelines, thanks a lot. With the caveat that everything works as long as I connect to the radio via local (meaning that I need to connect to my remote shack mac) in SmartSDR and xDax. If I connect to the radio via Smartlink (remotely from my Macbook Air), xDAX only allows me to open one Dax at a time.
I´ve check the bandwith settings and everything is unchecked.
I will search the community now for this particular issue. Maybe @Mike-VA3MW would help.
THanks everybody for your support.
73, Santiago
HI8O
