TX power does not reflect adjusted power level.
Posting this to the Mac forum as this is the flavor I run on my Flex 6400. I realize this may be a hardware issue. Per the attached screen shot, I am unable to see TX power on FT8 near my set power limit. In this case, 40 watts. I also have the same issue when tuning up. As the screen shot shows, my tune up power is set to 15 watts but I usually only see 1-3 watts per the meter. I am able to make contacts. Every now and then, the TX power will get close to the adjusted power level but not often. I have removed power from the 6400 multiple times, reboots etc., with no immediate change. Am I missing an ALC adjustment here, maybe this is normal? Appreciate any insight.
Jay (K7GFH)
Just curious, have you tried using WSJT-X versus the built-in FT-8 tool? In WSJT-X, you can adjust the output level. It would be interesting to see if you get any better results.
If you do, then I would suspect a software issue with MacSSDR, and reaching out to Marcus would be appropriate.0 -
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsALC won't have anything to do with this.
Let's start by making this simple.
What power do you see when using the TUNE slider at 100%? You should see 100 watts into a dummy load or close to it. If you don't then, the supply voltage at the radio is the next thing to look at and it needs to be close to 13.0V if at all possible.
The TUNE exercise tells us where to look next. Let us know..
"Just curious, have you tried using WSJT-X versus the built-in FT-8 tool? In WSJT-X, you can adjust the output level. It would be interesting to see if you get any better results.
If you do, then I would suspect a software issue with MacSSDR, and reaching out to Marcus would be appropriate."
Thanks Bill. I have not tried WSJT-X outside of Mac SSDR. I was about too today then tried a few more ideas. The easiest to explain is in AM mode. When requesting 50W of power, the AM carrier is roughly 3 watts. Same with the tune function, requested 15 watts, actual is 3 watts as well. I figure if these simple settings are not functioning properly, digital will not as well. I believe I am leaning towards a hardware issue at this point. I do have an open ticket with Flex and fortunately, the 6400 was a recent purchase from Flex so hoping for warranty support if a problem is found.0 -
The TUNE exercise tells us where to look next. Let us know.."
Thanks Mike. I am at roughly 13.14 volts when tuning at 100W. Requesting 100 watts yields roughly 20 watts. Requesting 15 watts yields roughly 3 watts. See attached screen shots showing both.
Jay0 -
Hi Jay, can you adjust your power supply up so that you are showing closer to 14 volts when transmitting? (I think that is what Mike was trying to say, not 13 V).
I can do that Len. Will bump it closer to 14 volts and give it a try. Thank you!
Jay0 -
Hello,
Here are two screen shots. 1st with 14.26 volts to Flex, no TX. 2nd shows voltage drop to 13.73 volts with TX, tune at 100 watts.
Thanks!
Jay
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptions@K7GFH If you can't get close to 100% with 100% tune and more than 13VDC, it is likely an issue with the radio. Tim and the guys will get you sorted out.
Support has been a bit busy, but they will get back to you.
Thank you Mike.
Jay
in MAC FT8, what was your TX frequency (audio freq in Hz) set for? Saw a Help Desk ticket come in yesterday where the frequency was just over 2900 Hz. The default TX bandwidth is 100-2900 Hz. That would cause low power in FT8.
For TUNE power, the radio uses the CW tone setting which defaults to 600 Hz but I’ve seen it at 100 Hz causing low power on Tune.
73 Dave wo2x
All,
Update to bring a close to this thread. Radio was sent back to Flex and repaired. From what I can gather through the help desk, their were no hardware issues with the 6400. A calibration was performed and the radio has functioned properly since I got it back. Not sure how the calibration was corrupted for lack of a better term? I would love some insight but regardless, all is well.
Jay
- 417 Community Topics
- 716 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 140 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 150 Contesting
