maestro control in multiflex
Flex 6700
ver 3.9.19
Maestro A model Multiflex
Antenna Genius
When I have SSD on my computer set A slice 28mhz ft8 and B slice set to 50-mhz ft8 and A slice on the maestro set to 40 meter cw, for example things works fine but if I send on SSd in the computer slice A, the Maestro switches to the feq, of slice A in the computer and the mode of slice A…aren't they supposed to be independent ?
Tnx bc
My issue is similar. When I am on my desktop and also on the Maestro C via Multi Flex (both on the same network as I am remote). When I switch antennas on the Maestro it also switches the antenna on the desktop. Won't change the freq but antenna is changed. Any ideas ?
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsAh0U, Yes, they are independent. You must be running some other software like FRStack and have the option on to track slices.
Rick, that can happen if you are using a single SCU radio. What model radio are you using?
Nope,,no other software running
Is it possible that you're using the SmartControl option on Maestro? It is designed to track Slices from another Client like SmartSDR for Windows. You would have to click on the SmartControl button when launching for this though.
- 693 The Flea Market
