Maestro battery
Why do you have to take the battery out? I can leave mine in without any problems.
The only thing I have ever heard is that the Maestro A/B wont charge the battery when the Maestro, And MOST of the Battery's Won't charge from the USB A port and only from the Micro_USB port anyway so even if the Maestro could the Battery couldn't.
Bret WX7Y
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsBack in first days of the Maestro A, the goal was to be able to charge a power pack for the Maestro at the same time as use it.
While the idea was sound, the OEM packs that people use all behaved differently. Some worked as they should while others actually killed the Maestro A to the point you couldn’t turn it on. I was part of the Alpha team then and I remember FlexRadio spending months trying to stabilize it. Ultimately the charging cable was removed.
- 692 The Flea Market
- 119 Aurora
