cw settings disappear
K0FG_Fred
K0FG_Fred Member ✭✭
edited June 2025 in Community Topics
On my 6400M and now on my 8400M whenever I change bands, normally using the profiles, the cw settings are set back to default. Sometimes only one or two get changed, sometimes they all are reset. Speed goes to 30wpm, sidetone to 80 and pitch to 600. I have saved and resave the profiles but it almost always happens, other types of settings seem to stay like I saved them. This happened with ver 3.8 and now with 3.9.
All else seems to be working fine. Except the GPS takes hours to lock onto satellites but then it seems to stay locked until I power down the radio. Fan noise is a little louder but not excessively so, no weird noises like some have reported, and this is a new radio, only had it less than a week so maybe they have made changes to the fan mounting.
Fred, K0FG
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    Hi Fred… When you say you 'change bands', are you doing this via selecting a new band from the 'band' tab on the left side of the screen, or are you switching to a different proflle?
    I (and a couple of others I know on the forum) use the latter — saving specific profiles for each of the bands and modes (i.e. 40m CW, 40m phone, 20m CW, 20m Phone, etc.). I find with this method, all my settings (including AGC-T) are automagically established 'just right' for the band.
    Switching bands via the 'band tab' (i.e. directly switching bands) seems (for me) to default to either the system defaults or the last settings it had for that band. Even switching modes on the same band directly (not via profile) seems to set everything to 'defaults'.
    Hope this helps.
  • Erik Carling EI4KF
    CW settings are radio persistence variables. One possibility is that the persistence database needs a reset.
    https://helpdesk.flexradio.com/hc/en-us/articles/200831185-How-to-Reset-the-Persistence-Database-for-a-FLEX-8000-FLEX-6000
    When I change to CW my settings return to how I set them. But I have previously encountered the same trouble and a reset cured it.
    Erik.
  • K0FG_Fred
    K0FG_Fred Member ✭✭
    Thanks for the help, but it did not work. I followed the instructions from the article by Tim and 3/4 of the cw settings were not the way they should be. So I went thru each cw profile, again, and changed each one just the way I wanted it. Saved each one and by the time I got finished I went back and loaded the first profile, it was fine. Then I loaded the second profile and it was not the way I saved it. At least 60 percent of the profiles were wrong. I will turn off the automatic profile save and see if that makes a difference. Maybe once I get them the way I want them, and don't automagically save them they might stay the way I want.
    Fred, K0FG
  • K0FG_Fred
    K0FG_Fred Member ✭✭
    I went thru all my cw profiles and set them, one at a time, with the proper values for my cw ops. After several hours I pulled up each profile and they seemed to have the proper values in them. Had to turn off the radio tonight due to thunderstorms but will check the profiles tomorrow.
    Thanks for your help.
    Fred, K0FG
  • K0FG_Fred
    K0FG_Fred Member ✭✭
    Still having problem with the cw settings not being maintained. Did the process recommended to reset the persistence database but no joy. As an example I set the radio to 20 meters cw. Then I set all the cw settings the way I want them; delay, speed, sidetone and pitch. Export the saved settings. They sometimes are correct and sometimes they are back to default values. Even if they are correct if I move to different freqs and/or modes and then recall the 20 meter cw profile they are often reset to default. Not always but eventually they do get reset to default values. Sometimes not all the settings get reset, sometimes only the speed, or maybe the pitch, or maybe 2 or 3 values get reset.
    Don't think this is a problem with ver 3.9 cuz I had the same problem with ver 3.8.
    Fred, K0FG
  • Russ Ravella
    Russ Ravella Member ✭✭✭
    Hi Fred,
    Just to chime in on this, I'm having a version of this problem too. In my case, no matter what I do I can't get CW speed and TX time to be remembered on one particular band (12M in my case). I've done the "reset the persistence database" thing, full factory reset, toggled auto save on for awhile (I usually have it off), all multiple times. I suspect I'd have the same problem if I tried to save things on other bands too but for now the profile values are what I want and I don't want to risk screwing them up.
    Definitely a bug.
    73 Russ KR6W
    Russ and Fred, if you have not, please open a support ticket. This is not normal and needs to be tracked.
    Here is what persistence is all about
  • K0FG_Fred
    K0FG_Fred Member ✭✭
    Opened a help desk ticket.
    Fred, K0FG
  • K0FG_Fred
    K0FG_Fred Member ✭✭
    Opened a help desk ticket and Tim responded. Following his directions I executed a couple programs (dism and sfc) built into Windows to clean up any problems with the Windows installation. So far the changes have been successful and the cw settings appear to be holding. Seems like it was a Windows problem, not a Flex problem. Thank you Tim for the help.
    Fred, K0FG
  • K0FG_Fred
    K0FG_Fred Member ✭✭
    After a couple weeks of having the cw setting stay correctly, now they are being reset to defaults. Not all of them, but some. Now running a new Windows 11 machine so whatever problem I had with Windows 10 is now duplicated, so maybe it was not a Windows problem. After running the utility programs Tim suggested the settings stayed as I had them set but now they are being reset.
    Fred, K0FG
  • Peter WB6POT
    Peter WB6POT Member ✭✭
    Hi Fred,
    I'm having similar problems. Submitted a ticket a couple weeks ago. Did a factory reset (exporting profiles without preferences) and then importing without preferences. That initially seemed to fix things, but only temporarily. Later tried another factory reset, but this time rebuilt profiles from scratch. Same problem still persists.
    In my case I'm seeing two issues. 1) CWX macros are not saved or being deleted. 2) After moving from band to band via new profiles (which works), selecting a new band by the BAND button (not profile) takes me to some oddball frequency on that band and not where I last was.
    Waiting to hear back from support.
    Peter - WB6POT
