Aurora Model Comparison
Aurora Series Comparison
Feature | AU-510 | AU-510M | AU-520 | AU-520M |
Transmitter Power | 1–500W HF, 1–200W 6m | 1–500W HF, 1–200W 6m | 1–500W HF, 1–200W 6m | 1–500W HF, 1–200W 6m |
Efficiency (Peak) | Up to 80% | Up to 80% | Up to 80% | Up to 80% |
Spectral Capture Units (SCUs) | 1 | 1 | 2 | 2 |
Slice Receivers / Panadapters | 2 / 2 | 2 / 2 | 4 / 4 | 4 / 4 |
RX Antenna Ports | 1 | 1 | 2 | 2 |
Transverter Ports (0 - +10dBm) | 1 | 1 | 2 | 2 |
Frequency Coverage | 30kHz–54MHz | 30kHz–54MHz | 30kHz–54MHz | 30 kHz–54 MHz |
Full Duplex | Yes | Yes | Yes | Yes |
Display | None | 8" 1920×1200 IPS Touchscreen | None | 8" 1920×1200 IPS Touchscreen |
Maestro Front Panel | No | Yes | No | Yes |
SmartSignal™ (Adaptive Predistortion) | ✔ | ✔ | ✔ | ✔ |
CESSB (RF Compression) | ✔ | ✔ | ✔ | ✔ |
MultiFlex™ (Dual Client Support) | ✔ | ✔ | ✔ | ✔ |
Integrated Tuner | ✔ | ✔ | ✔ | ✔ |
MARS/SHARES | No | No | No | No |
Integrated Power Supply | ✔ | ✔ | ✔ | ✔ |
Remote Operation (SmartLink™) | ✔ | ✔ | ✔ | ✔ |
External Display Support (HDMI®) | — | ✔ | — | ✔ |
GNSS / GPSDO Support | ✔ / Optional | ✔ / Optional | ✔ / Optional | ✔ / Optional |
SO2R Ready | — | — | ✔ | ✔ |
Power Input | 80–264VAC | 80–264VAC | 80–264VAC | 80–264VAC |
Dimensions (H × W × D) | 6.74" × 14" × 13.25" | 6.74" × 14" × 13.25" | 6.74" × 14" × 13.25" | 6.74" × 14" × 13.25" |
- 684 The Flea Market
