Is there a remote way to turn the DC power on to the 8600M?
I have installed a Wi-Fi powerstrip that turns on the DC power supply that powers the 8600M. After applying the DC power to the 8600M I have found that I have to press the momentary switch to start the rig. Is there a way I can turn on the 8600M remotely? I have a Maestro that I use to remotely to operate the 8600M and it seems counter intuitive that I must go local to the rig to turn it on, something I never thought of until I purchased the Wi-Fi powerstrip.
David, K1MT
Best Answers
Flex sells a complete kit to turn the radio on and off remotely.
Hi David, there is a REM ON jack on the back of your rig that can be used to remotely turn your radio on and off. I use this device in my shack. I use channel 4 to power the rig on and off and channels 1 - 3 to control an antenna switch.
Check out section 19.6.4 of the new Flex-8000 Hardware Reference Manual for more info on using the REM ON jack.
By the way, you should always power the radio off using the front panel button or the REM ON jack before turning off the power supply. Otherwise, you run the risk of corrupting the SD card. It is the same thing as powering off a computer gracefully before pulling power.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsTo follow on. When you use the Remote ON/OFF RCA connector, it completely shutsdown the radio cleanly.
The only part running is a small Power Control PIC.
Imagine your TV when you turn it off. Same idea.
Hi Mike,
The FlexRadio Remote On Plug and Play Kit (V2) comes with 4 items including an AC adapter to USB recepticle (assumed) and RCA PigTail to connect to the 8600M. If I plug the microUSB to USB A cable into a USB charging slot on my Wi-Fi powerstrip can I plug it into the MHCOZY TYWB 4CH remote switch to supply the power it requires and not use the AC adapter to USB recepticle?
David, K1MT
-1 -
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsHi David
Yes, the MHCozy is a 5V device and it really isn't fussy where it gets its power from as long as it is reliable.
If you turn off the WiFi power ****, then the MHCozy will go offline. If that works for you, then you are good to go.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsDavid,
The smart switch should have dry contacts on it, so it doesn't matter.
I didn’t think the 8000 series incorporated an SD card.
Correct. No SD card in the 8000 series. Having said that, it is still a good idea to power the radio down before dropping power as there is still a storage device in the mix.
Another crucial aspect of the Remote on setup is its dependency on the Tuya app. Within the app, you have the option to schedule a power-off (at 12:00 AM) and a power-on (at 6:30 AM for me, just a few minutes before my first net of the morning).
When attaching the RCA PigTail to the 8600M what terminals do the black and red wires connect to on the smart switch. BTW, last night I ordered the FlexRadio Approved Remote On Plug and Play Kit (V2). Hope to see you at Dayton.
David, K1MT
The last two of the switch. Here is the documentation: https://www.flexradio.com/documentation/mhcozy-wife-remote-instructions/
-1 -
why not have a software switch built into SmartSDR? Icom for example has the ability to turn their radios on or off from their app. Thus avoiding the hard power down.
My
MHCOZY 4-chanel USB 5 V AC/DC 7–32 V Smart WiF are very unreliable i have linked to Google home but it loss conection ,if i remove the usb 5 and reconect it showa upp and later its dissapear again.
Its very frustraiting
Lars SM4IVE
i Just this evening got the Sonoff 4CHPro linked and connected to remote on.
Question: Does the contact need to remain on for the radio to stay on or is the remote on just a momentary closure? I think it is the former but want to be sure.
Thanks.
Greg
hi Greg,
The contact remains closed while the radio is on.
72Dave wo2x
Just for Info, you can buy that MHCOZY (the approved solution) Amazon for just over $20, al lot cheaper than the $90 Flex want.0
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsThere are many IOT solutions you can purchase in various places. If you have a lot of things, I recommend the SRS Station Controller. It is made by a ham for hams. Lots of cool stuff it can do.
- 681 The Flea Market
- 393 SmartSDR API
- 98 Aurora
- 991 Maestro
- 965 Genius Products
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
