SO2R mode: can't toggle stereo
All the SO2R functionality seems to be working fine, with the exception of toggling stereo (with the tilde/backtick key) so that I can hear both slices at the same time.
I've run SO2R in the past with two separate radios and SO2R hardware, and toggling worked fine in that setup.
What might I be missing in my configuration?
I'm not sure if it's a problem with my N1MM configuration, or my Maestro configuration.
Have you got OTRSP set-up in SmartCAT?
Create a port that matches the one in N1MM.
Thanks Rich. Yes, I have OTRSP set up in SmartCAT, with:
-Slices: A/B
-Process: N1MMLogger
-Serial: COM11
In N1MM, I have COM11 configured with the checkbox "CW/Other", and in the "set" dialog box, I have:
-Radio Nr: Both
-Two radio protocol: OTRSP
And in case it's relevant:
In the "Logger+ Audio Setup" I have the following items selected in the dropdowns:
-SO2R: Single soundcard L/R
-DAX Audio TX
(I also tried using "SO2R: Two soundcards mono", but that didn't seem to make a difference.)0 -
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsDon't forget to check use "Internal Radio Codec". that isn't your problem, but I thought I would mention it.
Are you sure your ` key is actually a ` (backtick) ?
Could there be another program intercepting it?
this is what I have:
You are right! On our team's computer, AutoHotkey was used to map backtick to another function. Thanks so much for the suggestion!0
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsExcellent…. Glad that helped. And, yes, I have been burned by something similar more than once.
- 419 Community Topics
- 718 The Flea Market
- 226 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 334 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
