Operation
I have a 8600, PGXL,TGXL. and am buying a Stepiir Urban beam with the new optimizer controller ….I understand it needs the S12 cable. What else do I need? Is there a guide on how to connect and set this up?
Hi
Page 12 of this document
What about interlock to prevent transmission until Stepiir is ready? Or is this necessary?
Also, what if you have two stepiir's?, how do we connect two cables?
if you have two of them you daisy chain there controllers. Regarding transmission you simply have to wait. It only takes a few seconds all the while you can receive.
HTHI have a DB42 no problem
Peter
Peter
Q- What about interlock to prevent transmission until Stepiir is ready? Or is this necessary?
SteppIR says no damage if RF power is greater then 100 watts RF. SteppIR has a optional "relay board" to allow you to use the PTT wired connection from Flex PTT to SDA controller, to inhibit movement.
Q - Also, what if you have two stepiir's?, how do we connect two cables?
Set up a second CAT USB cable on the Flex, associated with the second cable FTDI id. Flex has two USB ports…..if you need more, add a USB hub.
Alan WA9WUD
I have yet to have a time when I needed instant transmit upon band change. It’s literally just a second before you can do so. It’s less than 100 watts to be safe but your SWR will be high. Really it’s a non issue. You can daisy chain the controller. I think it’s detailed on their website.
I see FRStack has a Stepiir tab, does apply to Flex?
yes
- 391 Community Topics
- 664 The Flea Market
- 157 SmartSDR+
- 441 SmartSDR for Mac
- 275 SmartSDR for iOS
- 265 SmartSDR CAT
- 206 DAX
- 386 SmartSDR API
- 61 Aurora
- 299 FLEX-8000 Signature Series
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 471 Remote Operation (SmartLink)
- 144 Amateur Radio Interests
