No PC Audio on 8400 with 3.8.21
New station. The PC is a Beelink, Winn11. I'm listening to audio just fine with a headset plugged into the Flex, but even after clicking the "PC Audio" button I get no Flex audio. I can listen to YouTube videos just fine through the computer, so I know it's working. This means I can't run any digital modes. I looked at a post with a similar heading, but that discussion didn't help. See capture:
Any ideas?
Glen
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsIn the VFO flag, hit the speaker and make sure the volume is turned up.
Yup, I missed that but still no joy.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsThe FlexRadio in PC audio mode plays the audio on the default sound card.
If you are sure that the default sound card is yours speakers, then please open a support ticket so we can figure out where the audio is being routed. This seems to be the most common mistake that happens from time to time.
OK, I found a setting in Windoze Sound Settings, Properties: General, Audio: Allow/Don't Allow. For some reason it was set to "Don't Allow". Changed that to "Allow" and made sure PC Audio was enabled on the Flex. Now things are working, mostly. Not getting demodulation in WSJT, but I'm getting closer…
- 684 The Flea Market
