CG Nat How do we get around it ?
KG5PTE
in Networking
Hello rumor around here is that Spectrum my ISP may be switching to Carrier Grade network area translation. (CG NAT) Is Flex working on a "work around" For smart link. I have a friend in FL that is having this issue.
Thank you.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsAt the moment, we are not working on a CGNAT work around but it has been discussed.
If we did it would likely be a monthly subscription for it due to the expense.
Check with Spectrum. I am sure they will sell you a fixed IP solution. 73
