How can I test the performance of the VPN to my remote shack?
m5kvk
m5kvk ✭✭
I use Zerotier to connect my home Lan to that in the remote shack. As such it's completely private and I can't use speedtest to test it.
Any ideas on how I can?
  • m5kvk
    ****. I used to use iPerf to debug network links. Must make a note this time.
    let us know how it goes.
  • m5kvk
    I use Home Assistant to manage the remote shack, so I installed the iperf3 integration and set up an iperf3 container on a docker server here at home. I was already using speedtest on the internet connection.
    Here are the results after a few days:
    Oddly, the VPN seems to have more bandwidth, however this doesn't make sense. I suspect that it is an artifact of using different tools to test each link.
    it might actually indicate that you are being throttled on the non-VPN data movement.
    Keep digging.
  • m5kvk
    Good point, and you’re right.
    I was forgetting that - because I am behind a CGNAT firewall - access to the Internet from the remote shack is via another ZeroTier VPN tunnel to a virtual server in the cloud. Otherwise, Flexlink doesn’t work.
    I’ll turn off the latter VPN tunnel for a couple of days to remove that.
    Would you mind writing up your ZeroTier setup at some point? Or, if it was someone else, can you post a link? I would be interested in reading that.
  • m5kvk
    Will do.
    I thought it was already there on https://garethhowell.com/wp/using-smartlink-to-access-my-remote-shack/ but it doesn't go into detail on the ZeroTier configuration.
