Is there a means of adjusting the attenuator/preamp on a 6000 and/or 8000 via the Maestro
David43
David43 Member ✭✭
I've gone over the Maestro user guide and there is no mention how to make this adjustment. Comments would be appreciated.
Best Answers
    Answer ✓
    Tap the ANT1ANT1 indicators in the upper left corner
  • K0FLY
    K0FLY Member ✭✭✭
    Answer ✓
    On the screen, touch the area which displays "ANT1ANT!" in blue and red. A drop down window will appear, just under the frequency display is a slider (RF GAIN), the slider adjusts the attenuator/pre amp levels.
    Gayle K0FLY
  • David43
    David43 Member ✭✭
    Thanks for the answers. Also, what is the recommended setting or guidelines, right now I am remote into a 6400 and it is set at -8dB?
  • David43
    David43 Member ✭✭
    Just found my answers in the guide in 32.4.2 Preamplifier / Attenuator Block.
