Cat not switching to transmit
knewberry
knewberry Member ✭✭
edited December 2024 in Third-Party Software
After installing 3..8.20 update, the VSP quit working on my 6400. It had worked fine prior to updating. I have tried to repair as per all the information I can find on here. I have re-installed the update and tried to repair the VSP. Even changed computer, but found the same thing, no VSP switching. What am I doing wrong or what am I leaving undone? Any Ideas?
Thanks, Ken, K5GI
    I created a support ticket for you.
  • knewberry
    knewberry Member ✭✭
    After opening a support ticket, #69483, 10 days ago, because after up dating to 3.8.20 I lost the ability to use CAT to key the transmitter on my 6400, I was told the problem is in the program I am using and not the new update. It was suggested I contact the the developer, but I know where that would go. Seems odd that the program worked fine before updating. I guess I'll just delete the program. Although I can breakout my Icom 7300 and continue using it. The program, EZ PIX, is used to send photos like SSTV, but sends faster and better. It is used by operators in many countries around the world. I suppose if Flex won't allow it to be used on Flex radios, it's a good way to **** out some programs that aren't to significant. I'm a little disappointed but I'll recover. Maybe some else has a fix for this.
    Thanks to FlexRadio for responding and thanks to anyone for help. Ken K5GI
  • knewberry
    knewberry Member ✭✭
    Update on my CAT switching problem. My friend in Indiana got me going with the EX-PIX program. The 3.8.20 version works with EZ-PIX with no mods of any kind. A few changes in set up solved the problem. Thanks to all. Ken, K5GI
