Can't Receive on FT8 WSJT-X
Hi,
I have been away from my Flex radio since February. I used to work FT8 daily; however, now I can 't get FT8 to Decode. I checked DAX on the radio Panel and set to DAX 2. I checked the DAX short cut, and the audio is streaming on DAX B. I also checked the sound card setting, it appears to be correct. When I switch to DAX 1, I receive decodes. What am I missing? See the images below
  • David Decoons, wo2x
    if you are receiving decodes when slice is set to DAX1 then the issue is in WSJT-X settings, change receive audio from DAX1 to DAX2.
    Both WSJT-X and slice DAX channel need to match.
    Hi Reggie, You are all set to receive on DAX channel 1. If you want to decode on slice B, change the slice B DAX Channel to 1.
    If you set the DAX channel to 2, you also need to change the WSJT-X soundcard input to DAX channel 2.
    Was there some reason that you don't want to use channel 1?
  • Reggie
    Reggie Member ✭✭
    DAX 1 is set to Channel A. I normally use Slice B for FT8, and It is assigned to DAX2 for Slice B.
    Reggie
    Hi Reggie, so you have a couple of choices. Either just change slice B to DAX 1, or leave slice B on DAX2 and change the WSJT-X soundcard audio input parameter to DAX 2.
  • Al K0VM
    Al K0VM Member ✭✭✭
    Is your PC clock time within 2 seconds of exact? check at time.is or time.gov with your browser.
    AL, K0VM
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    If the PC is Windows, install Meinberg ntp (free), and always be in time sync.
    You will stop decoding FT8 if you settings are wrong on the WSJT Waterfall view.
    Have a look at that screen in WSJT. Check the top scale and make sure that the scale goes from 100hz to 3000 hz.
