Warning messages on PGXL
operating on 8o meters I have gotten 2 diffrent Error messages that pop up:
1: HIGH SWR FIRM
2:High SWR RFP
Can anyone tell me what they mean and possible cause? the Manual only refers to a 'High SWR Warning"
73's
KJ6ZFS
Jioe
if the message is every time on 80 meters, there may be an issue with the filter module. Open a ticket for further support.
I had alarm High SWR on 80m and the reason was burnt 50 Ohm resistor in filter block.
73 Boyan
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsThis amplifier has the ability to detect faults long before the amp gets to full RF power out (about 10uS). What this means it sometimes it can find antenna issues that you didn't know you had and are not detected by antenna analyzers.
It can also happen if there is an antenna fault that only shows up on higher power.
It can be a cracked torroid in a balun for example.
I would recommend 2 things. One, test on a high power dummy load and see what result you get and then follow up with a support ticket.
- 419 Community Topics
- 718 The Flea Market
- 226 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 389 FLEX-8000 Signature Series
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 334 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
