Flex 6600 reboots after "Run" is selected on Maestro screen
johna8119
johna8119 Member ✭✭
edited September 2024 in Maestro
I hadn't used the 6600 for about 2 years, because the area of the shack had to have some "improvements." I reconnected the Flex to the antenna, amplifier, computer, etc., and after a bit of fiddling around, as well as updating the software, I have been able to get on the air and log some contacts. Yay.
I pulled out my Maestro, and when the screen shows Smartlink, I updated the software on it. After updating, when I tap "Run" the Maestro seems to be starting, but the 6600 shuts down and reboots, and the Maestro disconnects. I have connected the Maestro to the 6600 both using WiFi and ethernet, and the same thing happens.
Any suggestions?
Thanks. John
    This is a technical support issue. I've opened a support ticket for you.
This discussion has been closed.
