Is there a way of having XVTA or XVTB track the band instead of the slice? FLEX-6600
Right now, it seems to me that XVTx only stays persistent on the slice that it is assigned, not the band.
IE when operating satellites, switching from a v/u to a u/v satellite does not change the XVTx to track the band. (or v/v to u/u )
Slice A is set to Vhf with XVTA and Slice B is set to Uhf with XVTB. In SatPC32 if you switch satellites from a V/U to a U/V satellite, Slice A being Vhf and Slice B being Uhf to Slice A being Uhf and Slice B being Vhf, The XVTA and B do not swap.
Do I have something setup wrong?
Rig Flex-6600, XVTA is VHF (Q5 VHF Transverter single IF/RF), XVTB is UHF (Q5 UHF Transverter single IF/RF)
SatPc v12.10 slice A is radio 1, slice B is radio 2.
Without using any 3rd party program, In single slice mode switching bands VIA pressing "Band", "XVTR", then VHF 2M or UHF 440 (< my naming instance) the XVTA and B track the band. But in 2 slice mode they do not. So you don’t need SatPC32 to experience this.
Hope this makes sense.
George N1NAZ
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsHi George
The best way to do this is to use Global Profiles.
Setup a Mode B configuration (VHF down and UHF up). Save that as a Mode B Global Profile.
Now, do the same thing for Mode J and reverse the bands. Save that as a Mode J Global Profile.
When you change birds with different modes, recall the global profile first.
HI Mike
Thanks I will try that.
George
- 692 The Flea Market
- 119 Aurora
