What are people using for recording & playing audio messages?
What are people using for recording & playing audio messages? For example, calling CQ during a contest. Also, recording QSOs.
Thanks in advance.
    I use N1MM for contesting with the built in voice keyer. It is pretty seamless.
    If I really need to record a QSO, I use Voicemeeter.
  • Johan SE3X
    Johan SE3X Member ✭✭✭
    N1MM for contesting with the built in voice keyer and for other recordings and playback Audicity.
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    Windows Game Bar (Windowkey + G) works well for me, recording both the audio and the screen (panadaptor). The output can also be edited later using the app to select just the bits you want.
    I didn't even know that existed! Nice one.
  • kpaine
    kpaine Member ✭✭
    I am running N1MM and have always had great luck with my headset plugged directly into the radio and DAX turned on. Now I want to use a USB headset in my computer which requires DAX to be turned off. Now I cannot get the voice keyer to work with DAX off. What is the workaround for this situation?
    Thanks WB5SKM
