TGXL/PGXL/AG8x2 - PTT timing and connections for Flex and 3rd party radios
Several questions.
1) When using a network connection to control PTT for my entire Flex ecosystem, is 30ms the recommended delay? Does that only need to be set in the SSDR -> Radio Settings -> TX menu?
2) When using a direct PTT connection (from an external switch/foot pedal) with my 6600, and the remaining PTT control of my TGXL/PGXL handled by a network connection, should I use the same settings as above?
3) When integrating a 3rd party radio with TGXL/PGXL, what is the correct order to connect the PTT in/out cables between radio/tuner/amp? What kind of delays should be set for this?
4) Is it 'safer' to connect/configure my 6600 to send PTT out via RCA cables, like I would with a 3rd party radio? Has anyone tried that?
Thanks!
I’ll chime in:
- yes
- yes
- radio -> TG XL -> PG XL. You should also have a CAT/CI-V connection from radio to PG XL. In TG XL under Genius Integration, enable Power Genius and enter IP of amp. Use correct firmware versions. pG 3.8.4, TH/AG pair either 1.1.20/3.1.5 or 1.2.11/4.1.7
- No. LAN PTT is reliable.
- 73 Dave wo2x
Thanks Dave, your responses are always quick and concise!
Would you consider LAN PTT to be more, less, or the same reliability as RCA PTT?
This might help as well. I think we are now at 40ms.
Thanks Mike! What are your thoughts on using RCA PTT input/output with a Flex radio and TG/PG?
I saw a post where you (I think it was you) suggested using a physical PTT in to the TG, then TG to PG, and PG to the radio. I like that idea, but it would limit remote operations... at least I think it would.
K5IUC
I use physical connections from TX1 on my 6400 to my KAT500 tuner and then to my KPA500 amp. Works great locally or remotely.
Whether the rig is keyed locally using the PTT socket or remotely using the ethernet connection, TX1 is triggered and behaves the same.
Correction on my post in response to PTT delay.
Mike is correct. For the complete Dream Station we recommend 40 ms. Also if using an OEM exciter make sure to set the Tax delay on it as well.
73 Dave wo2x
Got it, 40ms delay across the boards, no matter if LAN PTT or RCA PTT on Flex or some 3rd party radio.
Thanks! Are you using 40ms?
Yep. I had it at 30, and never got a hot-switching fault, but decided to up it to 40. I can't tell the difference operationally. I do quite a bit of CW (but not much contesting) and it is totally fine.
40ms is about 1 dit length at 30 wpm if that helps as a reference.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
