2 radios on 1 computer
Anton
Anton Member ✭✭
Hello. I have 2 6400 radios. Please tell me is it possible to run two radios on the same computer for use with N1MM? 2 SmartCAT programs do not start. Maybe there is some kind of solution? Thank you, 73!
    Unfortunately no.
    You can run 2 versions of SmartSDR but only 1 copy of CAT.
    For SO2R, the design is to use a 6600 with the better band pass filters, built in OTRSP and seamless integration to N1MM.
  • Anton
    Anton Member ✭✭
    > @Mike-VA3MW said:
    > Unfortunately no.
    Thanks! That's what I did! Now I am the lucky owner of 6600
