Assigning Antenna Port per Band
Is it possible to specify which bands use which antenna ports? I have a 2m transverter and, when switching from 2m back to an HF band, the slice will be on the XVTR port and it's easy to forget to switch it.
    KD0RC Moderator
    I use global profiles for that purpose. I have one profile per band and mode. I seldom change bands using the band selector. Instead, I select the appropriate profile.
  • minorsecond
    Thanks Len. I suspected using profiles was a solution but wanted to see what folks said. I'll have to start using them I suppose!
  • Rich M5RIC
    Or use a third party app, flex buttons is a great tool which I use for changing band and mode as multiple settings can all be assigned to 1 button e.g mode, band, slice, rx antenna, tx antenna, dax channel etc.
    Keith has done a great job developing this recently.
    This might help.
    • TX profiles are auto saved
    • TX Profiles are are related by the TX Slice Group Mode and that loads the correct MIC profile
    • The Global Profile pulls in the right Transmit Antenna selection
    It helps if you change bands/modes by Global profiles that you have previously saved.
