Koss SB-40
Will the Koss SB-40 plug directly into the 6400 ? Or do i need to adapt the stereo mike plug back to mono ?
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    According to the 6400 hardware manual, I think you'll be fine. The MIC plug on the Koss is already mono and looks to be the same config as the MIC jack on the 6400. the HDPH plug on the Koss is stereo (TRS) and also appears to be compatible with the HDPH jack on the 6400.
    With my SB-45's I had to use a Stereo to Mono adapter.
