Recording Transmit Audio
My question is, when doing this am I just capturing the raw mic stream from the iPad's mic? Or is what I'm recording the actual audio that's modulated, including adjustments from the equalizer and processor (if I have it on)? The reason I ask is because even though I get reports of excellent audio using the iPad's mic, making adjustments to the EQ (or turning it off) doesn't really seem to make much difference in how the recorded audio sounds when I play it back. The only way it will record the stream is if the radio is transmitting, so am I getting raw audio or modulated audio when doing that capture?
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsYou are capturing the raw mic stream.
If you want to make audio adjustments after the EQ, CESSB part, you want to run the radio in Full Duplex by starting a 2nd slice on the same frequency with a different RX antenna (XVTR).
This is how you do it on Windows. You can do the same thing on a MAC I think.
Thanks, Mike. That's what I suspected. Yes, the iPad version of SmartSDR has FDX mode. But I didn't know it could be used to listen to your transmitted audio. I'll give that a try. Thanks!1
- 419 Community Topics
- 718 The Flea Market
- 226 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 334 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
