FHM-2 and flex 6600M
There are times I prefer a handmic over the other mics. I have an FHM-2 BUT it seems to need an incredible amount of drive for it to work even half as good as my dynamic mics. Mic gain set at 80 or more, +20db and bias are on.
This leads me to a second question, is there a schematic for the FHM-2? I opened mine up and found a bunch of cold joints on the side of the board thats shows when you pull the bac and touched them up, that didn't help. in the mean time I found that R 2 was missing. That's on the front of the board, across the mic leads. Should it be there and if so, what's the value?
Sandor KG4FET
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsThere is no schematic available.
Are you sure they are cold solder joints or is it just the non-lead solder that looks like a cold solder joint?
I created a support ticket for you.
The solder joints I touched up were dull. They are all shiney now. Thanks for opening the support ticket Mike
Sandor KG4FET
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsYea, that is the non-lead solder that has to be used.
I use the so called "silver" solder here too
- 714 The Flea Market
- 210 SmartSDR+
- 468 SmartSDR for Mac
- 129 Aurora
- 993 Genius Products
- 138 Antenna Genius
- 331 Shack Infrastructure
- 235 Networking
