Smartlink still not working after 3.5.9 update on 6600M
Updated the 6600M and still have no internet on the radio? Anyone else? The option to login appears for a few seconds then goes away.
Jeff N3VE
Hi Jeff, I would submit a help desk ticket.
Downgraded to 3.5.8 then upgraded to 3.5.9 and smartlink is working now.
Still not working, was intermittent, now not working again.
Mine is not working on SDR on Windows or SmartSDR on Mac. Wasn't working before updating firmware or after. Have tried downgrading and it's still not working. Says no internet connection (which I obviously have since I'm typing this) and the registration fields on SDR for Windows flashes ever so briefly and so doesn't allow credential entry.0
Same here... wasn't working before updating the firmware or after. Still can not configure SmartLink with the message "This radio does not have an internet connection". I opened a ticket.
All of this is very frustrating... just want to be able to sit down, turn the radio on and expect it to work. When it works, it is great, but I have no confidence it will work when I do turn it on. These SmartLink issues are occurring too frequently.
I followed the upgrade instructions for 3.5.9 and I'm still not able to connect to my Flex 6500 via SmartSDR on my iPhone or iPad.
When I try to connect, I receive the following message: "Error connecting to SmartLink Service"
I'm really hoping this is fixed soon.0 -
Similar experience on my 6300 - upgraded to v3.5.9 earlier this afternoon (CDT in US) and it worked for a while, but now it's refusing to connect via SmartLink stating that it cannot find any radios. A larger question to answer is, "Why does this seem to happen every few months?"0
The silence is deafening.
Plus for me is I am having a blast using the new to me Hermes Lite 2 HF SDR. Got it running a have been getting some great signal and audio reports. Driving SPE amp with 5 watts from the Hermes. Thetis is a bit of a learning curve at first but I just love the interface skins you have to choose from.
So, whilst annoyed I cannot access the 6400M remotely at the moment I am still getting my daily radio fix.
I am sure the tech's at Flex will get the issue sorted, eventually. Perhaps they may even learn just how important a RELIABLE smartlink server is. Always, seems to be as soon as contest season starts to roll in there suddenly becomes an issue. A very good reason to not put all of your eggs in the one basket long term.
Tim, VK6EI.
Yes am experiencing the same issues with 6400M saying it doesn't have an internet connection, clearly it does but someone mucked up some code along the way.
My flex6400 is unable to connect to smartlink. Smartlink has worked before, but when I log in, I get a message that the internet cannot connect and my signal and name do not come up. Can now only run locally. It is also not possible to connect the iPad or iPhone remote via smartlink. I have gotten everything working before both with smartsdr 3.4.23 and 3.5.8 also briefly with 3.5.9. Is there a big problem with the software for the flex radio?0
The very first thing you have to do is upgrade to 3.5.9. That will give you access to the SmartLink servers. Unfortunately, radios that have not upgraded will continue to ping the servers and they're currently overloaded. That means even if you have upgraded you may not be able to connect. But if you're persistent, and keep trying, you should be able to. I am currently trying to connect again this morning, but I'm not successful. Flex may have turned off the servers while working on them. Last night I was able to connect intermittently.
Remember that all three of the main programs must connect (SmartSDR, CAT, and DAX). When everything was working, this usually happened automatically and almost immediately.
Those who are experiencing SSB "clicking" or motorboating in their audio are likely picking up these constant connection request pings from the computer noise getting into their audio. Some are even reporting noise in their RX audio. Try a different microphone or get better cable separation from your computer until this gets fixed. In the past, I found that balanced microphones like the P40 are particularly susceptible to this computer noise. Usually, it's not a problem since there is little computer traffic.
One user changed from his P40 back to the OEM hand microphone to solve this computer noise pickup problem and his motorboating went away. Once (if) you connect, the noise should stop.
It is important to note that even if you're not using SmartLink, your radio will continue trying to connect to it... and even if you've installed 3.5.9. No server connection will show up as a "Radio Internet: NONE!" warning.
This is quite the mess and thousands of radios are constantly trying to log in every time they're turned on. That doesn't sound like a good design practice in hindsight. But for now this will probably continue until EVERYONE upgrades or until the Flex engineers find a miracle cure on the server end.
Fred
K9SO
It is going to take some time to reduce the load on the SmartLink Servers. It will eventually clear.
Thanks for your patience and we continue to monitor the server performance.
"It is important to note that even if you're not using SmartLink, your radio will continue trying to connect to it..."
What is the reasoning behind this behaviour? Why put a demand on SmartLink servers, and elevate the risk of suffering from connection request computer noise, for a service that is not currently being used?
Erik
9/15 - As of now (9AM Im sitting here looking at this all morning)
@Mike-VA3MW I have a suggestion... if it is ever possible... perhaps having TWO root servers would be appropriate. The first for radios and software that are at the current/corrected version levels not to overload SmarkLink servers running the most up-to-date releases -- and the second for those that are not at the most recent release.
This way, people can be automatically routed to those servers best able to accommodate their version and not overwhelm root CA certificate servers used by still previous/out-of-date/malfunctioning versions.
Is this a legitimate idea? Could different Root CA certificates be recognized coming from different SmartSDR software/radio firmware installs in order to direct those radios to the most appropriate Root CA certificate server? Versions 3.5.9 and 2.10.1 would communicate with one Root CA certificate server and "all others" would communicate with another... thus assuring that people who update their radios and software are directed to a CA server that is not being overwhelmed by other (out-of-date) users?
How disgusting flex is giving me... every day I am more disappointed, if I could go back I would never have bought 2 flexradio. The service that these unpresentable people are providing to their clients is a shame. If I have paid the high price of 2 flexradios it is for the remote option, if I knew that they were going to be without a remote I would have bought another SunSDR 👎️
I tried to get in twice today, 9AM and 11AM. Both times SmartLink never showed the radios. I logged out and back in successfully but the radios never came up. Small companies can't afford high publicity mistakes. I will leave it at that.
Mine started working about 19:00 UTC on Friday September 15th . Fingers crossed it stays solid!
Steve
K9ZW
When I try and Log In via smart link I get a strobing effect on the Apps window.
If I don't use smartlink all seems normal.
Ian
KM4CQG
No luck in Raleigh, NC...
For the latest update on the SmartLink outage, see https://community.flexradio.com/discussion/comment/20605830/#Comment_20605830.
- 395 Community Topics
- 674 The Flea Market
- 187 SmartSDR+
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 87 Aurora
- 325 FLEX-8000 Signature Series
- 984 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 313 Shack Infrastructure
- 218 Networking
- 837 Peripherals & Station Integration
- 146 Amateur Radio Interests
