SWR HIGH RFP Error
I've opened a help desk ticket for this issue, but thought I'd post here in case anyone else has run across it:
Over the past week I have noticed my PGXL throwing random ‘HIGH SWR RFP’ errors. Yesterday, it starting doing so continuously.
I have two antennas, a K4KIO Hexbeam and an Alpha Delta 40M Dipole. The amplifier will error on both antennas. I have checked the SWR on both antennas with an analyzer and it is below 1.5 on both. The error occurs on all bands
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsCan you test into a dummy load as well?
The PGXL can deal with very quick transient loads and show an error in as fast as 10us. Sometimes an RFP trip can be related to something within the entire antenna system.
Doing a dummy load test just helps to add some additional information.
I loaned out my dummy load a couple months ago and it walked away. I'll order a new one today
Depending on what Radio you drive it with the TX Delay can vary a lot
Try setting your TX delay IN THE RADIO to 30ms and see if the Error comes back, If it is still there try going a little higher on the TX Delay.
I think what is happening on some radios is that the AMP has RF Power hitting the SWR alarm circuit before the TX/RX Relay is fully closed and trips the High SWR Interlock alarm.
I set the TX Delay to 50ms and ran into a dummy load and the same issue is occurring. Flex support is looking into it and hopefully it is just operator error. I will report any findings here
This morning Flex support logged into my computer and everything seems to be working. I am absolutely baffled as just last night I was getting the error running into a dummy load. I feel like the fella who takes his car into the dealership for a problem that cannot be reproduced at the dealership!
Thanks to flex for their great support as always
- 996 Maestro
