Fixed IP Input for Smart SDR
You can set the radio (server) to use a static IP address. Go to SSDR Setting>Radio Setup>Network>Advanced. You'll have to be connected to the radio to set the fixed address ( direct or through a router ). You'll need to ensure the address is compatible with your network.
Or you could reserve an address for the radio in your router (my preference).
If you're talking about the client ( SSDR ), It users the address of the computer and you can reserve a fixed ip for the computer in your router.
AL, K0VM
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptions@dl7fp
To answer your question. No.
The radio will do a network broadcast on your entire network so that SmartSDR can actually hear the radio.
This makes it very simple and very reliable.
I hope that helps, 73
Thanks very much to you both!!
Best 73 Fabian0 -
Sure, fixing the IP-address of the RADIO is supported and useful (in my network, fixed-assets received fixed-IPs generally).
But I don't see it as an either / or choice to allow SmartSDR to connect to a specific IP-address. I've read your previous messages, Mike, about the larger population of users being less network-savvy, and I completely understand (like, and use) the auto-discovery of the Flex Radio by SmartSDR through the use of broadcast packets.
But I also ask (URGE) you to consider and support less-complex VPN setups by simply allowing the user to specify the target IP address of the Flex radio. Hide it behing an "Advanced" button if you wish, but this small request - which doesn't conflict or negate existing function - would be a huge enabler for so many. Layer 3, baby!
Thank-you
3 -
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsI will pass on your message Gord.
There are numerous cookbooks available that might help you out. Have you given any thought to trying?
I only say that is that if you take the time to learn it, you will be in control of your own solution and not waiting for someone else to do it.
> Thank-you
Exactly, that would also help me a lot, as I could then simply use wireguard.
Thank you Gord!
73 Fabian1
- 198 SmartSDR+
