TGXL Export Memories Per Port
CJ WT2P
Member ✭
Howdy-
One thing that's annoying for me is I reset the tuner memories for ports A & B, then before a contest go through each band and perform a tune for antennas I plan on using for each band, usually on Port A.
What I would like is that once I've done that for Port A there's some way to copy those same settings to Port B. I am using SO2R with external switching (no AG). I have to repeat the same thing, for the same antennas on Port B.
Even better, would be the ability to save that configuration somewhere and just import it back in. My antennas don't change that much.
Is there a way to "export" the tuner memories for port a/b to a file, then load that back in for either port or both ports?
WT2P
WT2P
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsHi CJ
I would send an email to support@403a.com and ask them directly.
CJ
If you do email 4o3a and get a response could you post it here.
