Smartlink stopped working with 6400
Smartlink was working on my 6400 but stopped at some time recently. Nothing has changed with my network. I have ports 4994 and 4993 forwarded to the 6400. I've tried connecting to the radio with a Windows laptop and my iPhone off my home network but no dice. I've unregistered and re-registered the radio in Smartlink. I've also rebooted the radio.
The smartlink test in SmartSDR fails.
Is the service down, or is there anything else I can try?
Are you using SmartLink locally or remotely?
It is designed to only work remotely.
If you are trying to get SmartSDR working locally, don't use SmartLink, just connect directly. This does require that your computer or Maestro be on the same network segment as the radio.
Remotely. I tried from a coffee shop and I've tried at home with my Phone as a hotspot, and using the iOS SmartSDR software with Wifi turned off.
Ah, OK. You might want to submit a help desk ticket then. The Flex support staff are pretty good at figuring out network issues.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsCan you describe what 'fails' means. A bit more details please.
- Can you see the radio in the radio chooser?
- If so, can you actually connect to the radio?
- Or, does it time out connecting to the radio?
One thing I have discovered is that I turn off IPV6 on the SmartSDR App on my iPhone, I have much better success. My Radio is not on an IPV6 network. I'm not exactly sure how that figures into things, but it does require more investigation.
Morning Flex world. I´ve been having issues connecting to my 6400 with Smartlink recently. From a couple of days ago it is impossible for me to connect using smartlink. I´m logged in in Smartlink, I see the radio on my iphone and ipad, but when I select connect it does not.
I´ve verified my local router and ports 4993 and 4994 are forwarded as it should be (as far as I know) but no connection is achieved. If I click on test smartlink it fails.
Any feedback will be appreciated.
Santiago , HI8O
Santiago
I have had the same issue.
Interesting, I have two Flex radios, and one of the two work just fine on SmartLink.
Doing a Flex Radio Factory reset fixed the SmartLink problem radio.
Alan. WA9WUD
Thanks Alan. I will consider that option.
73, Santiago
For the past few days, I also experience difficulty connecting remotely / Smartlink. On my Win10 PC, I get the forever-circling blue "busy" indicator, but never a connection.
Fortunately, I have the Flex "Remote On/Off Kit" where I can perform a soft-shutdown, and turn-on. When I do that, every time, Smartlink and remote connection begin working nicely again. Weird, and it never used to be this way...
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsWhat would be very useful would be to know what the settings are in your router when this happens.
- Are the port forwards the same as the radio is expecting?
- Is the IP address of the radio still the same matching the port forwards in the router?
It sounds like the port forwards are 'sleeping' in the router (if that is even possible).
What happens when you reboot the radio is that the radio then sends the correct commands to the router and that is why the radio starts to work.
Unfortunately, this problem will likely continue until the root cause is understood. To me, it sounds like an issue with your router. Once we know why, then we can address fixing it.
I'll keep an eye on things, and see if everything returns to "normal" again. Over this past weekend, I changed-out my decade-old ISP modem for a new, modern one (with clearly "nicer", more-progressive traffic-shaping).
The Port Forwards on my Ubiquiti UDM-Pro remain as they've always been, but because of the modem-change I rebooted this baby for good measure also. This UDM-Pro is 10Gb/s fiber-connected to my managed switch, thence over to my ham-room. Prior to rebooting the UDM-Pro, 'ifconfig' showed me not a single dropped-packed during the 6 weeks' uptime ... so, I think my side of things remains steady, and solid.
But my third-party ISP (TekSavvy) uses underlying infrastructure provided by my local cable company (Shaw), which was recently acquired (by Rogers) and they are initiating changes (DOCSIS 3.0 banned by Dec, hence my choice to get on-board with their mandated DOCSIS 3.1 *now*). However, this is good hygiene, and may/may not be connected to my SmartSDR recent "busy" indicator.
I can only say, for sure, Monday begins well with the usual quick SmartSDR connection to my Flex from office at work.
"Customer to monitor" :-)
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsGotcha...
This isn't a dropped packet issue.
All the hardware you have can interrupt the communications. If the WAN address changes (an ISP issue), then the radio will not work on SmartLink if for some reason the new WAN IP address is not detected or sent to the FlexRadio servers.
You might want to keep a watch on the WAN address and see if it changes. If the WAN IP address doesn't change and the port forwards don't change and the forward the inbound connections to the radio correctly, then you'll have to dig deeper.
I assume you have UPnP turned on. Is that the UDP-Pro that is the router or is the router on the modem? Or, is it just a network switch? It is hard to tell from Ubiquiti's web site.
- 409 Community Topics
- 707 The Flea Market
- 207 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 125 Aurora
- 367 FLEX-8000 Signature Series
- 984 Genius Products
- 360 Tuner Genius XL
- 328 Shack Infrastructure
- 233 Networking
