Anyone Successfully Running with Smartlink into a TP-Link DECO MESH network?
I have a 6400 running just fine within the LAN in my second home, but cannot get SmartLink to successfully support WAN access via SmartLink from outside. I suspect configuration settings for my network are the problem, and hoping that someone is successfully running a near identical setup and might help out. The network continues to work fine in every other aspect, including several other remote access appliances and systems.
SmartLink is the only problem.
Flex 6400 running Ver 3.4.24 software, accessed with both SmartSDR for MacOS and SmartSDR for Windows successfully on the LAN.
My network:
Kinetic/Windstream cable internet access at 200MbS
Cable Modem: Hitron CODA-45 Modem (runs in bridge mode only according to manufacturer and ISP)
LAN: four TP-Link DECO M9-Plus MESH devices (up to date software from TP-Link), one primary DECO as router using a single ethernet connection to the modem. All DECOs are up to date and working fine for multiple devices (both wireless and ethernet) on the network including multiple streaming devices, weather station, remote WAN access to Lennox HVAC system, remote access to Hot water system, weather station etc.
I configured the DECO router for NAT port forwarding: ext.: 21000 => Int: 4994 and ext: 22000 => int: 4993. uPNP is enabled.
I have reviewed the network Smartlink Youtube videos and the SmartSDR manual in detail. There is no access to the cable modem, nor any user configuration capability. The ISP has not been helpful in multiple calls (one rep did not know what "bridging" is).
When I run the SmartSDR for MacOS SmartLink test from inside the LAN I get the following report:
I don't know what to do at this point. I have a home setup for a 6300 which runs fine both internally and remotely via SmartLink.
Any help would be greatly appreciated...
Bill
KK4C
Hi Bill -
One of the radios on our SmartLink account is connected to a similar network and its behavior has puzzled me for a couple months. Did you make any progress on yours?
Thanks,
Greg W8XY0 -
greg,
evrrything is working fine now. But after slmost a year, i cannot recall what i did to succeed. I believe that I found that the Deco M9 device did not function properly as the DHCP server and bridge modem. I switched to a dedicated Modem/DHCP up and everything is working fine now. So my only suggestion is to find a dedicated DHCP modem and use the Deco devices as Access Points.Hope this helps…
73s,
Bil
KK4C
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsI use the Deco MESH but I use the MESH in Bridge Mode as it is not my main router.
If you already have a Router, then you want the MESH in Bridge mode so that the management of the network is handled by the main router.
You set that in the Primary unit and turn off the Router functions.
Essentially, based on what you said, you are double NAT’d. Changing to Bridge mode should resolve that issue.
Thanks Bill and Mike -
Here's my deal - here in SC I have a Verizon modem providing Internet and DCHP duties with the Deco mesh devices (X20's I believe) in access point mode. 6400 is wired into one of the mesh devices in a separate shop. It is assigned a fixed IP.
The radio seems to work perfectly when I run SmartSDR while on the local network. I have UPnP enabled on the modem and manually forwarded ports 4993-UDP and 4994-TCP through it. The radio registers Smartlink connection without complaint and the test button gives me a green light. From a remote location, the radio shows up as available, tests green, but will not connect. Two other radios on the account work fine.
Another interesting symptom is that the test button mouse-over shows that UPnP ports fail and forwarded ports pass. The other two radios on the account show all four ports pass.
Any advice? Thanks,
Greg W8XY0 -
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsYou may wish to open a support ticket.
Bill, Mike, Greg
I have similar but different problem. Perhaps your expertise and experience can point me toward a solution.
On the tp-link deco mesh router (only router ), I have manually set TCP and UDP port forwarding to 4994/4994 and 4993/4993 respectively. Also set address reservation for radio to its current IP address of 19.168.68.83, and UPnP is also enabled. In the SmartSDR Smartlink setup, the radio is REGISTERED, and network settings manually se t ports 4994 and 4993. Te test fais (all four points). The only thing I can see that is not kosher is that the router has the radio in is OFFLINE list.
Any ideas?
Don AA5DE0 -
You could try this - sorted my issue but who knows…
Turn off the radio, in the Deco list of offline clients delete the entry for the radio. Ensure no address reservation either.
Turn radio on and Deco in my case found it and allocated a DHCP address. Then re-allocate a reserved address. The radio will be (or should be) in the online list now. Mine has been perfect since.
Erik, thanks for the suggestion. It didn't work as planned, bu when it disappeared om all lists, I stumbled across the option to reboot the router(s). Now the radio is back online with a dozen or more other unknown devices - what a crazy connected world live in. Strangely, some devices, such as Tuner Genius previously on line are now offline; doesn't appear to affect operation (maybe?).0
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsThis is a pretty hand tool to figure out what is going on with your router and PnP ports.
Yes I have the same. Also my PGXL appears as an IoT device. But it all works perfectly and now you have it running I would simply, as I do, leave it alone.
