Smartlink working but no audio or waterfall
Hi everyone,
I have loaned my spare 6300 to a radio club that is more than a 5 hour drive away to allow club members to have remote access to their shack. They have about 1MBup and 10MB down ADSL internet on site.
The club IT guy has done the required port forwarding, and the radio shows up in Smartlink. I can connect to it just fine using either my home network or the on a different PC in my office.
However, there is nothing on the pan adapter and no audio is being passed either as per the screenshot below
When I change bands, I get a warning flag about the interlock preventing TX.
The radio worked fine at home before I shipped it out, and I do not have access to a PC on the remote site to update to the latest SmartSDR - it is currently on 3.4.21.
Is this a port forwarding problem? Reducing the panadapter width to a 2.4KHz and the waterfall refresh rate to 1 also makes no difference (reducing the internet BW required).
I have looked in the community and changing the MTU makes no difference either.
Thoughts? I will try and arrange for a remote VNC session when the club meets next week.
Cheers
Steve, M0BPQ
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsI opened a support ticket for you.
What was the resolution to this…I am having the same trouble
Bill0 -
I'm interested too in this problem as having upgraded my 6700 too v4.0.1 last week to work with my PC running Win11, I upgraded SmartSDR on a laptop running Win10 this morning.
All works fine on the LAN but I get the same lack of signal/audio from the panadapters as Steve got above, when connecting via SmartLink over a 4G signal. CAT and DAX both appear to operate normally
Trying to avoid sending a help ticket if I can
73 John, G3WKL
John, after the upgrade did you do a radio reset and cold boot, always essential after an upgrade.
Rich
Rich
Yes, and the radio and PC still work fine on v4.0.1
It's the laptop that I installed SmartSDR v4.0.1 on this morning that isn't working when it is connected to the radio via 4G (WAN). The laptop works properly when connected on the LAN, so it would seem that it's a SmartLInk setting
I've checked the port forwarding on the router
Rich
Problem found - it was an extra, incorrect, port forwarding rule in the router that was difficult to delete - it kept re-appearing
73 John, G3WKL
hi there, I have the same problem, but with a Mac and 8400, no sound no scope, do you remember what rule or port? If there anyone help, thank a lot max0
This was a port forwarding issue in the end! I think they needed to dedicate the rules specifically to TCP/UDP and not both. 73 Steve
- 409 Community Topics
- 707 The Flea Market
- 207 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 125 Aurora
- 367 FLEX-8000 Signature Series
- 984 Genius Products
- 360 Tuner Genius XL
- 328 Shack Infrastructure
- 233 Networking
