What causes this bump in my panadapter?
KD0RC
I have a Flex 6400 with a UT5JCW transverter for 2 meters. It works great, but I do see a large (nearly 10 dB) bump in the receiver response. Is this showing me the bandwidth of the transverter or am I seeing the bandwidth of the antenna? The antenna is a Ringo Ranger ARX2B.
I am asking this out of curiosity, not because I have any problems with this setup.
  • Geoff AB6BT
    Geoff AB6BT Member ✭✭✭
    Antenna resonance???
    Well, I think that I just answered my own question... I disconnected my antenna, and still see the same bump. I switched from my vert to an 11 element Yagi and get the same thing.
    I conclude that it is the bandwidth of the transverter that is showing on my panadapter. If anyone has other insights on this, I would be interested to hear them.
    These are the kinds of things that I never would have noticed without my 6400!
  • Duane  N9DG
    Duane N9DG Member ✭✭
    edited June 2023
    It probably is the response traits of the transverter.
    Curious though, how much more pronounced is the bump if you zoom the display out to the full 7 MHz?
    And what do you see if you run a second 7 MHz wide display either above or below 2M? Doing the two displays immediately adjacent gives you a frame of reference spanning 14 MHz.
    Hi Duane, I did look at the 7 MHz wide chunk and it did not look any different. I agree, it is the transverter response that I am seeing.
    I would be interested to see what 144 - 148 looks like on a Q5 transverter. My guess is that it will be considerably flatter.
    Hi Len
    If you where to take 100 readings with a signal generator across that entire spectrum and plotted it, that is what it would look like.
  • Lasse SM5GLC
    Lasse SM5GLC Member ✭✭✭
    You could try change the RX path from "28 common" to "RX only", open JP2... this would show a bandpass that is less steep on the high side due to the "top-loaded" bandpassfilters used on VHF... There is a LPF-filter in the common path that may cut the high side of what you see.
    All this is pure specutlations as I do not hve the transverter, only looking at the schematics :)
    BTW what is the corner frequency of the LPF in the flex (WB filter enabled I guess)?? Do you use 28-32 MHz IF?
    Hi Lasse, once you tune higher than 146 MHz (30 MHz IF), the rig goes to "Wide". Also, if you have any panadapter showing more than 28 - 30 MHz IF it will go to Wide. Wide is a good thing...
    My transverter will tune 144 - 148 MHz, so that is an IF of 28 - 32 MHz.
    The Flex is quite flat, it is the transverter band pass that causes the non-flat response.
    I am not looking to "fix" anything, my original post was just curiosity as to what I was seeing.
    I would say that I have learned more about radio in general since I got this 6400. Being able to see things like this makes it obvious what is going on.
  • Lasse SM5GLC
    edited June 2023
    Len,
    that's why I wrote LPF... i.e. the wide is just a low-pass filter at the input of 6400, but depending on the cut-off frequency it could aid reducing the noise, but assume it has a lot higher cut frequency (it should remove the aliasing of ADC).
    And my comments were just beeing curious on why the noise looks as it does... I even d/l the schematics to see what was going on :)
    I have seen similar "****" but on lower frequency, but that is more likely due to a narrow resonant antenna.
